Latest post 12-08-2009 4:52 AM by Peter. 4 replies.
Page 1 of 1 (5 items)
  • 12-08-2009 3:15 AM
    Stripping an Avant or BV32 for non-B&O Flatpanel usage
    Hello do-it-yourselfer,
    my actual DD 5.1 setup consists of BV3-32 with Beolab 5000 and CX100 (MCLP driven) as rears. The BV3-32 acts as center.
    I am playing with the thought to strip an Avant or BV3 in order to use it only as control box for B&O integration and to keep the 5.1 availibility.
    Here is a project in the forum dealing with combination of a 50" flatpanel and an Avant. So obviously there are possibilities.
    Who knows if such a stripped Beovision would be operatable without tube. I would put the sound coming out of the cable TV receiver into this Beovision rest and via HDMI/Scart I would feed the flatpanel. Of course I will loose the setting possibilities of the Beovision because there won't be any access to the menu.
    2nd issue is the center speaker. Maybe I could use a Beolab 7.1, which brings me to the problem connecting it to the Beovision internals.
    Just brainstorming....
    If anybody could spend its 50 cents...
    Thank you
  • 12-08-2009 3:49 AM In reply to
    Re: Stripping an Avant or BV32 for non-B&O Flatpanel usage
    Take a look at this thread!
    Graham
    I used to be indecisive, now I'm not so sure. [W C Fields]
  • 12-08-2009 4:21 AM In reply to
    I'd use the speakers and amplifiers in the Avant if possible - remember the BV5 is really an Avant with a flat screen.
  • 12-08-2009 4:42 AM In reply to
    @Peter
    Yes, I am aware. But my feeling is, that the video signal processing on acual LCD panels is much better than the Beosystem 2. I don't see any stumbling blocks, don't I?
  • 12-08-2009 4:52 AM In reply to
    Agree with that - the video processing on the BV5 is the archaic bit really. I don't see why you couldn't feed the pre-amp out to the Avant power amplifiers though. Need a bit of working out the connections but you sound well up to this!
