Hello do-it-yourselfer,
my actual DD 5.1 setup consists of BV3-32 with Beolab 5000 and CX100 (MCLP driven) as rears. The BV3-32 acts as center.
I am playing with the thought to strip an Avant or BV3 in order to use it only as control box for B&O integration and to keep the 5.1 availibility.
Here is a project in the forum dealing with combination of a 50" flatpanel and an Avant. So obviously there are possibilities.
Who knows if such a stripped Beovision would be operatable without tube. I would put the sound coming out of the cable TV receiver into this Beovision rest and via HDMI/Scart I would feed the flatpanel. Of course I will loose the setting possibilities of the Beovision because there won't be any access to the menu.
2nd issue is the center speaker. Maybe I could use a Beolab 7.1, which brings me to the problem connecting it to the Beovision internals.
Just brainstorming....
If anybody could spend its 50 cents...
Thank you
