Latest post 12-08-2009 3:19 PM by tournedos. 4 replies.
Page 1 of 1 (5 items)
  • 12-06-2009 11:17 AM
    • richtoy
    • Top 500 Contributor
    • Joined on 09-20-2007
    • Valkenburg, Netherlands
    • Posts 184
    • Gold Member
    LX/MX motor stand plug wiring
    I have aquired a motor stand for my old LX but it has lost its plug.
    There are 4 wires; green, white, yellow and brown.
    Does anyone know to which pin each wire goes?
    Better still, if anyone has one could you possibly open the plug and post a picture?
    Thanks,
    Richard
    Some of my B&O: BV3/32, MX7000, MX5500, LX5500, MX4000, BM8000, BM6000, Overture, BL8000, BM6000 Quad, BM4400, BM3400, BG-CDX, BM3000, BM1001, BM1200, BM1600, BM1700, BM1500, BM1400, BM2400, BM2300, BM4500, BM4000, BVM70, BVS45-2, BVS60, BC7700, BM2200, BM1900, BG8002, BM1202, BVPenta, BVP45
  • 12-06-2009 11:26 AM In reply to
    Re: LX/MX motor stand plug wiring
    • B&o bottle opener
  • 12-06-2009 11:44 AM In reply to
    • richtoy
    • Posts 184
    • Gold Member
    Thanks Jaff
    I have a similar diagram in my LX5500 manual but it does not state which wire is which.  As a last resort I can strip the stand down so see which colour wire goes to the motor and which to the position transducer but I was hoping to avoid that if possible...
    Richard
  • 12-08-2009 2:50 PM In reply to
    • richtoy
    • Posts 184
    • Gold Member
    In case anyone else ever needs to know how to wire an MX motor stand I will document it here: -
    Pin 1 - Yellow
    Pin 3 - White
    Pins 2 & 4 - Green & Brown (pins 2 & 4 are connected on the board)
    The motor unit has far more to it than I expected; 2 pcbs with some kind of Intel chip, a crystal, about 6 small capacitors and lots of smd.
    Richard
  • 12-08-2009 3:19 PM In reply to
    Thank you for posting Smile I've seen this asked a number of times, and I don't think anybody ever provided the answer.
    The stand communicates with the TV using a serial data protocol, and so must have its own brains doing the actual work. That Intel chip must be the microcontroller then.
    -mika
