Latest post 12-05-2009 4:59 PM by Peter. 3 replies.
Page 1 of 1 (4 items)
  • 12-05-2009 3:15 AM
    • classic
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Venø - Struer / Denmark
    • Posts 224
    Retipping of SP 12 - Technical improvement
    I have developed a method to measure the frequency response of B&O cartridges.
    I have used this method to find the technical part of improvements by retipping the B&O SP12 cartridge.
    I can prove a major improvement of performance as a result of the fine work - done by Axel Schürholz - info@schallplattennadeln.de
    The test.
    I used the same pickup unit and tested using 2 needle parts. The first needle parts was a original B&O where I have checked the diamond by microscope - all ok. I performed the frequency response test.
    Next I changed the needle part to a re-tipped elliptical diamond - done by Axel, and the frequency response test once more. Exactly the same conditions.
    The result:
    From 500Hz and up the frequency response was clearly improved and with the higest result at the top end (high frequency range) where the improvement is more than 5 dB (this is a very big improvement)
    The tonal balance is much improved and in the following listening test the difference was very clear.
    See the frequency response here.
    /Frede
    Beolab 5000 -  "If another amplifier sounds different then it needs repair!"
    Filed under:
  • 12-05-2009 7:33 AM In reply to
    Re: Retipping of SP 12 - Technical improvement
    Most impressive! Maybe Soundproof and I need to send you our stylus collection to measure the differences!
  • 12-05-2009 2:25 PM In reply to
    • classic
    • Posts 224
    Peter,
    I will be happy to measure your collection of stylus collection.
    However, we have to remember this test will be a test of the total pickup. Because for the SP units I can change the stylus only, this is not possible for the MMC cartriges.
    A true test would be a MMC before shipping to >Alex and a test after Alex has performed his 'magic.
    But - Peter and Soundproof - if you would like your cartriges testes, please send them and I will do it for you.
    /Frede
    Filed under:
  • 12-05-2009 4:59 PM In reply to
    I am sending a collection back to Soundproof soon - his and some of mine and I will suggest he passes them to you next! Just waiting for a different pressing of Time Out to arrive!!
