Latest post 12-06-2009 5:03 AM by mr_anders_son. 8 replies.
Page 1 of 1 (9 items)
  • 12-03-2009 12:47 PM
    BeoCenter 1 - strange issue please help
    I have disconnected it for some hour.And when I connected it again it ask for pincode. I tried 3 times and then it locked
    Now after many hours without electricity it says only "Wait" and turn on and after 1 min it turns off and then turns on with "wait" and so it
    does repeatly......?????
    So I have no chance to put in mastercode
    Someone??????Confused
  • 12-03-2009 2:10 PM In reply to
    Re: BeoCenter 1 - strange issue please help
    mr_anders_son:
    I had the same experience when I first bought my BC1. Leave it plugged in for about 4 hours (or overnight) and the 'Wait' message will eventually disappear and you can then put in the PIN. Turning on and off will make things worse-  my dealer has told me that this is an additional security feature.
    Graham
    EDIT Make sure you leave the mains power on. If you only get three attempts at the PIN before all of this procedure repeats, you could be in for a long night if you can't get the PIN right first (or third) time!
    I used to be indecisive, now I'm not so sure. [W C Fields]
  • 12-03-2009 3:37 PM In reply to
    Ok thanx
    but my dealer says I shall leave without power for couple of hours, but it didnt work
    So I shall try your tip
    Yes I have attempted 3 times than it happendSad
  • 12-05-2009 7:49 AM In reply to
    Ok your it works no. I get the menu pincode and then I hold left arrow 3 sec and then mastercode menu comes up
    Great so far BUT....my dealer needs serialnr but I cant find it. The shelf is repainted so I can not see it on the back
    I have put the back of and looked inside but I can not find 8 digits serial there
    What shall I do????
    It must been there somewhere or must I take it to my dealer? What can they do?
  • 12-05-2009 3:44 PM In reply to
    mr_anders_son:
    What shall I do????
    The 8 digit serial number is under the cable entry cover at the back of the TV (on the large label with all the other electrical compliance data).
    Graham
  • 12-05-2009 4:13 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    You can find the Serial Number by entering the Service Menu.  PM me and i'll walk you through it Smile
    Lee
  • 12-06-2009 3:32 AM In reply to
    vikinger:
    mr_anders_son:
    What shall I do????
    Graham
    but its overpainted[:'(]
  • 12-06-2009 3:42 AM In reply to
    9 LEE:
    Lee
    You got PM
  • 12-06-2009 5:03 AM In reply to
