I have a Beolit 600 with a broken antenna. Does anyone have a spare they'd like to sell me?
Is it a standard antenna or B&O specific?
My B&O: 2009 Catalogue and Pricelist
bump
I'm certain it's specific to B&O. These and the Beolit's volume/tone sliding knobs are like hens teeth these days - I'm referring to the 70's model. Your best bet is to buy any old tatty beolit that has a good aeriel and swap it over.
Steve
If you think nobody cares, try missing a couple of payments.
Yes, they are B&O specific. And very much so, I'm afraid.
BTW; There are two, very different, types of Beolit 600. Antennas are different too so it may help if you clarify which model you have.
oops sorry, the later square 70's version with external power supply.
Thanks for the responses, they're very helpful.
Now, just to find one.........
Hi
Just joined Beoworld.
Do u still seek an antenna for the Beolit 600?
Best regards
Trigi
(Denmark)
Hi Trigi,
Definitely!! I'll send you a message.
Best,
Jonathan
