Latest post 02-07-2010 7:11 PM by Jonathan. 6 replies.
Page 1 of 1 (7 items)
  • 11-29-2009 12:47 AM
    Beolit 600 antenna
    I have a Beolit 600 with a broken antenna. Does anyone have a spare they'd like to sell me?
    Is it a standard antenna or B&O specific?
    My B&O: 2009 Catalogue and Pricelist
  • 12-03-2009 10:24 PM In reply to
    Re: Beolit 600 antenna
    bump
  • 12-04-2009 5:19 AM In reply to
    • Stonk
    • Top 50 Contributor
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    I'm certain it's specific to B&O. These and the Beolit's volume/tone sliding knobs are like hens teeth these days - I'm referring to the 70's model. Your best bet is to buy any old tatty beolit that has a good aeriel and swap it over.
    SteveSmile
    If you think nobody cares, try missing a couple of payments.
  • 12-04-2009 7:43 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Yes, they are B&O specific. And very much so, I'm afraid.
    BTW; There are two, very different, types of Beolit 600. Antennas are different too so it may help if you clarify which model you have.
  • 12-07-2009 11:17 PM In reply to
    oops sorry, the later square 70's version with external power supply.
    Thanks for the responses, they're very helpful.
    Now, just to find one......... Erm
  • 01-30-2010 10:15 AM In reply to
    • Trigi
    • Not Ranked
    • Joined on 01-29-2010
    • Ry, Denmark
    • Posts 21
    • Gold Member
    Hi
    Just joined Beoworld.
    Do u still seek an antenna for the Beolit 600?
    Best regards
    Trigi
    (Denmark)
  • 02-07-2010 7:11 PM In reply to
    Hi Trigi,
    Definitely!! I'll send you a message.
    Best,
    Jonathan
