Latest post 12-08-2009 9:37 PM by ICE. 2 replies.
Page 1 of 1 (3 items)
  • 11-28-2009 3:43 PM
    • ICE
    • Not Ranked
    • Joined on 10-19-2009
    • Montreal, Canada
    • Posts 11
    • Gold Member
    BEOGRAM 3404
    I'm interested in acquiring a BEOGRAM 3404 (Ebay) to use as a 2nd deck to my BEOGRAM 1700.
    This would serve as my rig to CD/server as I have an extra MMC20EN and my 1700 would be dedicated to my audio system.
    Question : Is this BEOGRAM 3404 reliable/ worthy in terms of performance ?
    The selling price on EBAY is $125 w/shipping-insurance and stated by the seller to be in perfect working order and cosmetically veery good.
    Any opinions/advice would be appreciated ! Thanx, Ihor
    Filed under:
  • 11-28-2009 5:02 PM In reply to
    Re: BEOGRAM 3404
    Yes - good radial deck. A US only model but I believe it was made to go with the Beomaster 2400 in later days. It has the lightweight arm but the mount for the older cartridge type - similar to the 2402 in the EU.
  • 12-08-2009 9:37 PM In reply to
    • ICE
    • Not Ranked
    • Montreal, Canada
    • Posts 11
    • Gold Member
    Re: BEOGRAM 3404
    Hi Peter, Thanks for your corroboration and +comment. I did buy this deck and pleasant surprises do occur; the seller did not BS and the 3404 rates a +8.5 condition functionally and cosmetically.
    Unlike wine, this BEOGRAM did travel well !
    On a different note regarding your cartridge tests : I fitted this latest BG3404 with a MMC20EN circa 1984 and it does sound flatter (smoother) vis-a-vis the SSMITH SMMC20EN however I appreciate the extended hi-end on the SSMITH and it's quite probable that my MMC20EN is a bit tired (suspension). I calculate minimum 500 hrs use since -84.
    Thanks for your reply and your excellent reviews...
    Regards, Ihor
    Filed under:
