Hi Peter, Thanks for your corroboration and +comment. I did buy this deck and pleasant surprises do occur; the seller did not BS and the 3404 rates a +8.5 condition functionally and cosmetically.
Unlike wine, this BEOGRAM did travel well !
On a different note regarding your cartridge tests : I fitted this latest BG3404 with a MMC20EN circa 1984 and it does sound flatter (smoother) vis-a-vis the SSMITH SMMC20EN however I appreciate the extended hi-end on the SSMITH and it's quite probable that my MMC20EN is a bit tired (suspension). I calculate minimum 500 hrs use since -84.
Thanks for your reply and your excellent reviews...
Regards, Ihor
