I have bought a LK FUGA® indsats lysdæmper TOUCH IR 350 UNI http://dansk-el.dk/product.asp?product=5740
How can I learn my BEO5 to controll this dimmer?
BeoSound3000, Beolab8000, Beovision8-26, Beo5 and BeoCom4
Hello.
I Have the same problem...
Pleace sombody help...??
/Uldall
Beosound century Beocenter2 Beolab2 Beolab3 Beolab8000 Beolab6000Black Beolab4000 Beovision Avant 32 DVD RF MX7000ML MX4200ML MX1500 Beolink1000 Beo1 Beo4 Beo5 Beosound1 Beosound6 Beocom2 Beocom6000 Serene BeoPort A4 A8 A9 LC1 LC2 Kabinet 2168 Black line FORM1 Beotime Beotruck.
As far as I know LK Fuga dimmers are controlled by colored buttons in LIGHT mode.
Try command: 0:000:LIGHT:CNTL_STEP_UP for Light - blue.
Hi Uldall
I can see your are from denmark
Read this PDF-file Download
My Bang & Olufsen....
Remember to check the Continuous checkbox, this will repeat the latest command in the IR list.
Hi Tillquist
Mange tak så virker det :)
I just read your post dating from 2009 concerning the LK FUGA Dimmer.
Did you manag to install it in a standard-european-socket ? Or is Sweden based on danish electrical standards ?
Best regards,
Jean-Luc PUTZ
