Latest post 01-08-2012 2:35 PM by jlputz. 6 replies.
Page 1 of 1 (7 items)
  • 11-24-2009 10:42 AM
    • Tobias
    • Not Ranked
    • Joined on 04-17-2007
    • Sweden
    • Posts 32
    Light dimmer
    I have bought a LK FUGA® indsats lysdæmper TOUCH IR 350 UNI http://dansk-el.dk/product.asp?product=5740
    How can I learn my BEO5 to controll this dimmer?
    BeoSound3000, Beolab8000, Beovision8-26, Beo5 and BeoCom4
  • 11-24-2009 11:26 AM In reply to
    Re: Light dimmer
    Hello.
    I Have the same problem...
    Pleace sombody help...??
    /Uldall
    Beosound century Beocenter2 Beolab2 Beolab3 Beolab8000 Beolab6000Black Beolab4000 Beovision Avant 32 DVD RF MX7000ML MX4200ML MX1500 Beolink1000 Beo1 Beo4 Beo5 Beosound1 Beosound6 Beocom2 Beocom6000 Serene BeoPort A4 A8 A9 LC1 LC2 Kabinet 2168 Black line FORM1 Beotime Beotruck.
  • 11-24-2009 4:28 PM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: Light dimmer
    As far as I know LK Fuga dimmers are controlled by colored buttons in LIGHT mode.
    Try command: 0:000:LIGHT:CNTL_STEP_UP for Light - blue.
  • 11-24-2009 4:32 PM In reply to
    Re: Light dimmer
    Hi Uldall
    I can see your are from denmark
    Read this PDF-file Download
    My Bang & Olufsen....
    • BeoCenter 2 DAB/DVD mk.II
    • BeoVision 7-40 DVD mk.III
    • BeoLab Penta mk.III
    • BeoLab 4000 icepower
    • BeoLab 4000
    • BeoLab 3500
    • Beo 5
    • Beo 4 mk.I & mk.III
    • Beocom 6000
    • A8 Earphones
  • 11-24-2009 8:18 PM In reply to
    Re: Light dimmer
    Remember to check the Continuous checkbox, this will repeat the latest command in the IR list.
  • 11-25-2009 11:35 AM In reply to
    Re: Light dimmer
    Hi Tillquist
    Mange tak så virker det :)
    /Uldall
  • 01-08-2012 2:35 PM In reply to
    • jlputz
    • Not Ranked
    • Joined on 01-30-2011
    • Posts 3
    Re: Light dimmer
    I just read your post dating from 2009 concerning the LK FUGA Dimmer.
    Did you manag to install it in a standard-european-socket ? Or is Sweden based on danish electrical standards ?
    Best regards,
    Jean-Luc PUTZ
