Latest post 11-18-2009 8:00 AM by stefan. 3 replies.
Page 1 of 1 (4 items)
  • 11-17-2009 4:26 PM
    • hebo
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Sweden
    • Posts 305
    HD-module and HDR1
    Is the HD-module working OK together with HDR1?
    Is it easy to make timer recordings?
    pros and cons?
     BV10
  • 11-17-2009 4:49 PM In reply to
    Re: HD-module and HDR1
    one con might be that the recordings will be 4x larger (my guess) and therefore the HDR1's storage will be consumed even faster than normal
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 11-18-2009 7:54 AM In reply to
    • MikaelB
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Herning, Denmark
    • Posts 191
    I use the HD moudule (in BV7-40 Mk IV) together with HDR2. Which should be the same as your setup.
    Using the EPG to find the show I want to record and just press Red and Go on Beo4 then it will record from the DVB-HD module.
    It is an analog recording. It consumes the same amount of space as recording from analog turner.
    One major drawback in my opinion is that the DVB-HD turner in the TV is locked while recording. So you can't watch an other channel while recording.
    /MikaelB
  • 11-18-2009 8:00 AM In reply to
    • stefan
    • Top 50 Contributor
    • 200 miles from Struer
    • Posts 1,733
    HDR1 and HDR2 are not able to record HD quality. They will record a down converted SD version via SCART. So it will take the same space as normal. This is what my HDR2 does, when it is recording from my HD set top box.I don`t own the DVB HD module, but DVB S/T module, and I assume it works just the same way and that`s very easy.
    Stefan
