Latest post 11-18-2009 5:29 PM by CaFe. 5 replies.
Page 1 of 1 (6 items)
  • 11-16-2009 3:50 PM
    • CaFe
    • Not Ranked
    • Joined on 11-16-2009
    • Posts 3
    Beomedia Administrator Password???
    Hello Everybody,
    I have a big problem with my BeoMedia, it won´t start up.
    When I try to start up the Beomedia, it just asks the password for Administrator account login in Windows Xp Embedded.
    Have any of you been out for this problem before, and does anyone know the password for the Administrator account???
    //Carl
  • 11-16-2009 3:54 PM In reply to
    Re: Beomedia Administrator Password???
    I don't remember what was it when i started my Beomedia 2 years ago... Have you tried .... ''admin''  ???
    -Dimitris
  • 11-16-2009 4:05 PM In reply to
    • CaFe
    • Not Ranked
    • Posts 3
    Yes, I have tryed all kind of "ordinary" passwords, it should be something else.
    The problem occurred when we did some changes in the service menu...
  • 11-16-2009 7:26 PM In reply to
    Try a hard reset; i.e., unplug the beomedia, let the red pilot light go out and reboot.
    See what happens.
    Barry
  • 11-18-2009 5:30 AM In reply to
    Hi Carl,
    This happened to me, with the difference being that I had bought a used BM1 where the password had been changed from any of the ordinary passwords. In the end, as it is a computer, you need to bypass the login screen. It may help to try and reboot it and before it reads the OS, press (I think) F8.
    If that doesn't help you can always do what I did and talk with your dealer. Best of luck!
    //Carl-Henrik
  • 11-18-2009 5:29 PM In reply to
    • CaFe
    • Not Ranked
    • Posts 3
    Thanks for reply Carl-Henrik,
    Unfortunately, this does´t work either...
    I can´t bypass login window.
    //Carl
