I'd need your kind help again with my beogram.
After fixing the tracking problem, I connected everythin only to fnd out the only the right channel is working. The player is connected with the original DIN plug to a pre-amp. I had to take off the two pin's. The pre-amp is connected as well by DIN Plugs to a BS 9000. I know that this is working, as i checked that with a different record player.
I also checked that the DIN conectors of the pre-amp are OK with an adapter. The pre-amp also has chinc sockets. All tested and OK. The problem must be on the player side.
Any ideas how to narrow down the problem? I own the service manual, but have no clue what to look for.
Mafanni
