Am I satisfied and proud owner of a BV8-32 and I have a System Module laying around, right now I dont need the extra SCARTs or Masterlink on it, but I might wanna install it later, according to dealer it was just a matter of plug & play :) but read a thread here about a similar install on BV7 (was tho DVB-S/T module) but you had to use Bang & Olufsen ServiceTool after install. In my instructions its saying just that I should use ServiceTool after installing...
Now first question, It is only plug&play for this card? I dont need to do a flashupdate or sw update?
My plan is via Beolink Converter 1611 hook the BV8 to a BS7000, (speakers connected to BS7000)....
Second question, I will be able to choose on BV8 if and when BS7000 should start up its speakers? I can start TV always with its own speaker and then when I choose via menu use speakers on BS7000?
Hope I make myself clear :)
MoglesMac
Sweden
