It will probably need a minor adjustment to sort out. The left hand mechanism also acts as the mechanical link to operate the "lid closed" microswitch and any minor differences on the hinge repair will affect this as the tolerances are pretty tight.
If you look underneath the left hand side of the CDX there is a piece of black tape covering a hole. This hole is the access point to the adjuster screw, you will need a HEX/allen key to turn this and I would suggest only turning it no more than revolution at a time until the lid operates correctly. I think you need to turn it clockwise but I'm not certain - it doesn't really matter in any case as it simply operates via a cam mechansim which will eventually go full circle and end up where you started. Be aware though that it will also adjust the lid in a forward/backwards direction so don't go mad!
Chris.
