1st March February 2012
Latest post 06-14-2007 11:18 AM by Ericvr6. 24 replies.
06-13-2007 6:00 AM
Kevin
- Joined on 02-15-2007
- Moderator
- Posts 1,256
Hi all, I seem to remember we had this in the old forum but does anyone have a current colour for B&O white. I seem to remember it was a BMW match or was that the silver? Also has anyone a picture of a white RL speaker. thanks, Kevin
Puncher
- Joined on 03-27-2007
- Nr. Durham, NE England.
- Posts 9,588
Re: How white is B&O white
Kevin: Hi all, I seem to remember we had this in the old forum but does anyone have a current colour for B&O white. I seem to remember it was a BMW match or was that the silver? Also has anyone a picture of a white RL speaker. thanks, Kevin
Only pic I can find - the white looks pretty white to me!
Roger
- Joined on 03-28-2007
- Norway
- Posts 870
The white BeoSound 1 is "painted" with something that must be very close to NCS 0500 - I am sure someone can confirm the paint code for the BeoSound 1... The beamer colors could be found on e.g. the Avant - so no white's from Munich as far as I know. Roger
Kevin
- Moderator
- Posts 1,256
@Puncher thanks for the picture. A little dissapointed to be honest (not with the picture). I was hoping the cloth would be white as well, or at least a light grey/silver. And black straps! Thanks Roger (not knowing a lot about this) I assume this is a standard reference for paint colours?
Puncher
- Posts 9,588
Surely they will have been in the catalogue of the day - catalogues from 1992-96 anyone ???
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
I have spotted two pictures of RLs in white with light grey cloth on page 50 of the brochure from the mid 90s. The white brochure with the square hole cut out of the front cover (No date on it) Unfortunately, I don't know how to make my photo's small enough to add to a post. Andy T.
Puncher
- Posts 9,588
Thinking about it I'd be amazed if it were different to the white of BS5500 etc.
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
jandyt: Unfortunately, I don't know how to make my photo's small enough to add to a post. Andy T.
An easy way to do this is to email them tp yourself using the optimised (compressed) selection. @ Kevin, I'm not sure of the exact white but will it really matter when they are on the wall or is that a daft thing to say to an enthusiast? The BMW colour was indeed the silver as used on the Avant. Chris.
Puncher
- Posts 9,588
Medogsfat: . Kevin, I'm not sure of the exact white but will it really matter when they are on the wall or is that a daft thing to say to an enthusiast? The BMW colour was indeed the silver as uswed on the Avant. Chris.
Do Bears S**t in the woods??
Jandyt
- Posts 13,004
If this phot' works, Ill go and take a 'photo' of page 50. HERE GOES!!!!
Puncher
- Posts 9,588
Isn't that picture off topic !!
Puncher
- Posts 9,588
Thems the Fellas Spot on Andy!
Jandyt
- Posts 13,004
Right, I'm going to watch telly now! Andy T.
Puncher
- Posts 9,588
jandyt: Right, I'm going to watch telly now! Andy T.
nowt on mate!
Kevin
- Moderator
- Posts 1,256
@Chris you know me if your going to you might as do it halfway right lol @Andy thanks for that Puncher was right nothing on telly.
Medogsfat
- Posts 4,045
Are you thinking of clothing yours in white Kevin? I only ask as the cloth has to be stuck to the entire face of the cabinet fronts to obtain the raised lettering effect & the adhesive may bleed through & stain white speaker cloth - just something to bear in mind. When I recloth speakers I use evostick contact adhesive applying it to the cabinets or plastic frets only and it works very well as it sticks almost instantly. Chris.
Kevin
- Moderator
- Posts 1,256
White would look best but if the original is light grey I would stick to that Yes some kind of contact adhesive was the plan possibly the stuff used for photo mounting since it sprays well and is transparent.
Ignace
- Joined on 03-30-2007
- Moderator - NL
- Posts 2,749
Hi Kevin, i remember something about RAL-colour-codes that are often used by architects and so on, regarding B&O and colours, yes, B&O does use several of the colours that BMW also uses. Not sure which ones, but pretty sure about the metallic red-tones. I do have an original BMW colour-chart with the specific codes and designations, which i could send to you. Lee has used several specific colours to individualise f.e. Avant, i guess he could give you some pointers On the following link you can find BMW colour-codes BMW colour codes pdf of BMW colours per car-model
Ericvr6
- Joined on 04-17-2007
- The Netherlands
- Posts 205
kevin i rememer from the old forum the silver discussion (avant I think)
Page 1 of 1 (25 items)
