Excuse my ignorance but I have just attached a Mac Mini to my Beovision 6-26 with the dolby 5.1 surround sound card. I am currently using the standard mini jack to phone cable however I believe that if I use a digital output I will get better sound quality?
Firstly I'm not sure which input on the TV will work with the PC input as the only digital inputs I see are INPUT 1 which is listed as digital input for equipment connected to the AV socket and INPUT 2 - for digital input from equipment connected to the V.TAPE socket?
Then I need to get one of these
http://www.svideo.com/toslinkcoax1.html
and
http://www.svideo.com/spdif3.html
and
1m Toslink to Mini Toslink (3.5mm Minijack) Optical Cable
http://www.tvcables.co.uk/cgi-bin/tvcables/1m-toslink-mini-toslink-cable.html
Connect it all up and wow at the beautiful high quality audio?
Thanks,
Nic
