Latest post 06-13-2007 7:08 AM by Keith Saunders. 7 replies.
Page 1 of 1 (8 items)
  • 06-13-2007 3:38 AM
    Can not insert picture - please help
    Can somebody tell me how to add picture to the post? Thank you in advance!
  • 06-13-2007 3:55 AM In reply to
    Re: Can not insert picture - please help
    Make sure the picture is not too big and then click on the Options tab next to the compose tab. There is a button marked Add/Update just below where it says file attachment. Click that and then browse to where the file you want to add is.
  • 06-13-2007 4:00 AM In reply to
    • Toubro
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Copenhagen, Denmark
    • Posts 263
    In the "compose" part where you write your post, you can click the little picture highlighted below, for the box to come up.
    Your picture has to be online somewhere, and you just enter the Image URL and that's it :o)
    I'm having trouble getting the Link feature to work so it write a text you can click instead of displaying the actual link :o/
  • 06-13-2007 4:01 AM In reply to
    • Toubro
    • Posts 263
    Peter:
    ohh, I don't know this either :o)
  • 06-13-2007 4:43 AM In reply to
    Must the picture be online or can it be added from the computer as attachment?
  • 06-13-2007 4:49 AM In reply to
    It adds from your computer - but there is a limit to the amount of space you can use.
    To make a link work, type the word you want - Beoworld for instance! - highlight it, and the small link symbol becomes active. Click on that and you can add your link. I usually choose to open the link in another window.
  • 06-13-2007 5:31 AM In reply to
    I have succesfully uploaded the attachment but in the preview it can not be seen.
  • 06-13-2007 7:08 AM In reply to
    avus17
    If your filename has spaces in it, then remove them and try again
    Regards Keith....
