Hi
A quick question about cables, sorry if it seems a bit basic. I've got two and soon to be three sources fighting for input to my 7-40 via composite cables, ie PS3, HD Camcorder, and Apple TV.
It's a bit of a struggle getting behind the TV to change the cables, so I wondered if anyone else has a solution. I thought it might be possible to make up 5 individual cables, with the male ends going into the TV, and the other ends, close to my aforementioned inputs, as females, so it is possible to connect and reconnect the sources well away from the back of the telly.
Has anyone else tried this, or is there a better solution I'm missing. Obviously the scart sockets are all used up. If this type of cabling is available, where would I get it from.
Brian
