Latest post 11-06-2009 10:57 AM by David. 4 replies.
Page 1 of 1 (5 items)
  • 11-05-2009 12:13 PM
    • David
    • Top 500 Contributor
    • Joined on 05-05-2007
    • England
    • Posts 128
    Link TV Picture Problem.
    Hello Gents,
    I'm in the process of adding another link TV to my system.  This will be the fourth link tv coming off the RF Link Amplifer.
    The problem I'm having is that I cannot get a clear picture. The other TV's on the same amplifier have perfect picture quality.
    I have checked and even changed the co-axle cable and it made no difference.
    Link frequency is on the same channel.
    Music works fine and I can change channels on Sky with the B&O remote etc.
    Any ideas??
    Thanks,
    David.
    Beolab 8000, Beolab 6000, Beolab 2, LG CX65, Beosystem 3, Beosound 9000, Beolab 3500
  • 11-05-2009 3:03 PM In reply to
    Re: Link TV Picture Problem.
    Greetings David.Try swapping the outputs on the rf amp,if the picture improves on the new set,and degrades on one of the others,the amp must be faulty?Is it a B&O rf amp?
    Regards,
    Nick
    p.s.How's the Beomaster 6000 these day's?
  • 11-05-2009 4:06 PM In reply to
    • David
    • England
    • Posts 128
    Hello Nick,
    Yes I have swapped the outputs over and it's still the same.
    The red standby light is flashing now aswell. I will take another look tommorow and see if I can sort it out.
    Regards,
    David.
  • 11-06-2009 2:28 AM In reply to
    Hi David
    Have you also tried swapping the tv´s in your setup around. I know you say the cabeling should be allright, but just to make sure.
    The connectors at both ends of the cable can somehow be faulty or what do i know. What if you disconnect all other linktv´s, maybe it is a signal limitation even though 4 linktv´s should be possible!
    Regards
    Ehlerz
    BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
  • 11-06-2009 10:57 AM In reply to
    • David
    • England
    • Posts 128
    Hello Ehlerz,
    Swapped over the TV's today and the loan TV worked perfectly, so the cable and end connections are OK.
    I then tried the co-axle cable in the DVBS socket on the BV6 and the TV works fine? If I try and use the Link TV socket the picture has lots of noise????
    Confused now, but at least the TV has a good picture now.
    Cheers,
    David.
