1st March February 2012
Latest post 10-26-2009 8:38 PM by Sal. 12 replies.
10-25-2009 8:30 PM
mfirst
- Joined on 04-21-2007
- Posts 155
Universal Remote and B&O IR codes
Since B&O has to do everything differently then the rest of the known universe....
does anyone know of any universal remotes that will also broadcast the B&O frequencies
(I heard of one recently but it - surprise surprise - was obscenely expensive)
as I recall the beo5 does not control non-B&O stuff unless there is a lot of extra hardware?
-michael
Jonathan
- Joined on 05-03-2007
- Melbourne, Australia
- Posts 1,164
Re: Universal Remote and B&O IR codes
The Logitech Harmony range of remotes work with B&O. I have one and love it!! I don't use my Beo4 anymore....
My B&O: 2009 Catalogue and Pricelist
Keith Saunders
- Joined on 04-16-2007
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
Michael,
The Beo5 is capable of controlling 99.9% of 3rd party products (non B&O) directly (i.e. without extra hardware.)
PhilLondon
- London
- Posts 2,545
Keith Saunders:without extra hardware
... but you need a piece of software from B&O, that is very difficult to get, you also need small XML files that describe the remote's codes...
... or you need your B&O dealer to do it for you, or, as you'll see on the advert below, someone can do it for you.
Keith Saunders
- Posts 3,810
PhilLondon:
... or you need your B&O dealer to do it for you, or, as you'll se on the advert below, someone can do it for you.
True, but the question clearly stated, "without extra hardware"
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
I have done what Keith "suggests" with great results!
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
Clakke
- Joined on 02-01-2009
- Sweden
- Posts 108
jldmelb:
Hi
Also Philips Prestigo works fine with B&O. I use it to control B&O and Loewe. Like jldmelb, I prefer to use the Philips. It is much easier to use than Beo4.
BR
Clakke
mfirst
- Posts 155
What are the specific Logitech and/or Philips remotes that people like that work with the B&O?
There appears to be zillions of models and it is hard to find one that I like and will work with B&O...... and will probably need to buy online so returning it might be a problem
-michael
mfirst
- Posts 155
....and I tend to like the Philips since I have one of their TVs
-m
Clakke
- Sweden
- Posts 108
mfirst:
-michael
Hi
My Philips is called Prestigo, but the real name is SRU8015. I do not know what it is called today. It was a year ago I bought it.
Clakke
burantek
- Joined on 05-04-2007
- SE USA
- Posts 6,214
I am a big fan of the Logitechs... having a pair for two theater/media rooms that have been faultless. They were a snap to program and control everything that I have thrown at them. B&o specifically: Avant + BS9000
I will be doing a third theater/media room soon and yes, I will be buying another one!
mfirst
- Posts 155
ok - you Philips fans better be right!
http://www.gamerhotline.com/philips-prestigo-15-device-universal-remote/
on sale for $39.99
-michael
Sal
- Joined on 04-30-2007
- Indianapolis, USA
- Posts 261
I second the Logitech. I have a Harmony One and it worked great with all my B&O.
Sal
Love B&O, but no longer addicted.
Page 1 of 1 (13 items)
