Latest post 10-21-2009 6:33 AM by ........... 1 replies.
Page 1 of 1 (2 items)
  • 10-21-2009 6:19 AM
    beolab 8000 tweeters
    I have beolab 8000 speakers about 12 years old, they have been in for repair several times in their lifetime.
    When I remove front grill and place my hand on the tweeters ( on either speaker ) there does not appear to be any vibration.
    Are the tweeters blown and if so can I replace them myself or do I need to leave them with B&O.
    Would very much appreciate advice.
    Patrick
  • 10-21-2009 6:33 AM In reply to
    Re: beolab 8000 tweeters
    Hi Patrick. You will know if they are blown, trust me! You should feel a very slight vibration I would have thought but because of the nature of the frequencies that tweeters produce, they don't have to move much air so you wouldn't feel a great deal of vibration, if any.
    Hope this helps.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
