I'm back again. Rejeuvinated after a week in the sun
now its back to fixing things to while away the winter months.
Just had a tinker with the CDX and got it almost working despite the cracked touch panel. It recognises most discs with the occasional funny ? symbol on a few. But It has no sound. Or rather when you put the volume up to full you can only just hear the music above the background noise. (It's hooked up to a beocentre 4000)
The out put seems to be stereo, so it looks like the reading and decoding is fine, just a problem somewhere after that. Anyone know where I should be looking to fix this?
cheers AL
