bayerische:
Mika, I use "C", Cable from Welho. However in the future satellite or air transmissions are a likely source for me...
When it comes to satellite, you're off to get a separate STB anyway... in cable, I suppose this DVB-HD module should work just fine. I just read the user manual Peter has put on site and it seems to have a built-in CONAX module, so that will be fine for both T and C pay-tv in Finland as well.
What still remains open is the DVB-T2 capability. I don't think it is there, as it is not mentioned anywhere, and that would put B&O at the forefront of technology since nobody else has it either
From current knowledge, two terrestrial HD licences have been admitted in Finland (both to DNA) and the requirements specifically mandate that DVB-T2 should be used. Don't expect any regular transmissions in at least a year, though.
