This is my first post, I have just bought a Minette 512K Radio and I hooked up a 220v transformer and it worked both on AM & FM.
I does have a problem that there is a loud hum with no audio sound and when the volume control is turned up to 3/4 the sound comes on and the hum dissapears, but the volume is then too loud. If the volume control is moved from this one position then the audio is lost then the loud hum comes back.
Does anyone know where I could get a circuit diagram from.
Graham
