Latest post 10-26-2009 7:53 PM by Graham. 8 replies.
Page 1 of 1 (9 items)
  • 10-19-2009 11:52 PM
    • Graham
    • Not Ranked
    • Joined on 09-07-2009
    • Toronto Canada
    • Posts 5
    • Silver Member
    Just bought a Minette 512K Radio
    This is my first post, I have just bought a Minette 512K Radio and I hooked up a 220v transformer and it worked both on AM & FM.
    I does have a problem that there is a loud hum with no audio sound and when the volume control is turned up to 3/4 the sound comes on and the hum dissapears, but the volume is then too loud. If the volume control is moved from this one position then the audio is lost then the loud hum comes back.
    Does anyone know where I could get a circuit diagram from.
    Graham
  • 10-20-2009 1:47 AM In reply to
    Re: Just bought a Minette 512K Radio
    You need to talk to Martin - Dillen on site. Where are you based?
  • 10-20-2009 6:29 AM In reply to
    • Graham
    • Not Ranked
    • Toronto Canada
    • Posts 5
    • Silver Member
    I live in Toronto Canada
  • 10-22-2009 7:46 AM In reply to
    • Graham
    • Not Ranked
    • Toronto Canada
    • Posts 5
    • Silver Member
    Peter,
    How do I get in touch with Martin
    Graham
  • 10-22-2009 10:04 AM In reply to
    • Macus
    • Not Ranked
    • Joined on 09-14-2009
    • Kungälv, Sweden
    • Posts 25
    through PM in the upper right corner.
    Owner of a Beomaster 2400-2 and a pair of Beovox 1001 speakers.
    My other favourite brands are Apple, Philips and Infinity.
  • 10-22-2009 10:24 PM In reply to
    • Graham
    • Not Ranked
    • Toronto Canada
    • Posts 5
    • Silver Member
    Not sure what you mean by PM, can't find it.
  • 10-23-2009 2:35 AM In reply to
    • Macus
    • Not Ranked
    • Kungälv, Sweden
    • Posts 25
    Are yoy signed in?
    If you are, click on the word "inbox" in the upper right corner.
    Then write a PM to Dillen.
  • 10-26-2009 5:27 PM In reply to
    • Teddy_fr
    • Not Ranked
    • Joined on 04-16-2007
    • near Angoulême, France
    • Posts 250
    This is a beautiful radio very difficult to find! Please let us know of the steps of its restoration. I am sure too that Martin (Dillen) can help you in this task.
    It would be great if you could post a photo of yours?
    This one is unfortunately not mine but that of the Struer Museum! Big Smile
    Marc
  • 10-26-2009 7:53 PM In reply to
    • Graham
    • Not Ranked
    • Toronto Canada
    • Posts 5
    • Silver Member
    Hi Marc, I'm attaching a couple of Photos (not sure if I have downloaded correctly) of the Minette 512k and also a Jet 506 that I have also bought.
    the Radio seems to be in good shape and works on FM and AM eccept for the loud hum, I'm looking for a Circuit diagram so that I can check some voltages.
    I live in Toronto Canada so there is a 5 hr time difference
    Graham
