Latest post 10-25-2009 4:35 AM by kallasr. 13 replies.
Page 1 of 1 (14 items)
  • 10-16-2009 3:15 PM
    MX-4002 and passive speaker via MCL 2P
    Just bought an old MCL 2P to be used with MX-4002 in my garage.. MCL 2P connected to MX-4002 via powerlink.. Turned on PL-socket in menu.. but no sound Unsure
    MCL 2P has a red light - will this change to another color when in use? Could it be my cable? only connected 1 cable to socket 1 (think it is a standard power link cable from my BL 4000)
    Any ideas what could be wrong?
    Thanks..
  • 10-16-2009 4:08 PM In reply to
    • AdiS
    • Top 500 Contributor
    • Joined on 07-24-2007
    • Posts 196
    Re: MX-4002 and passive speaker via MCL 2P
    Hello Gordon,
    you don´t need the MCL 2P - the MX 4002 - as well as the MX 4000 - has two speaker sockets for passive speakers on the backside! So you can directly connect your passive speakers!
    regards, Adrian
  • 10-16-2009 4:14 PM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    try switching tv off then on - the 2p light should change to green and the speakers boot up!
    good luck
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 10-17-2009 3:47 AM In reply to
    Speakers directly connected to MX-4002 works fine, but I would like to turn off the tv speaker..
    Tried to turn on/off several times :-(
    Any ideas on the cabeling? I can'y connect a powerlink cable wrong?? can I?
  • 10-17-2009 4:46 AM In reply to
    • AdiS
    • Posts 196
    is it a full wired powerlink-cable?
  • 10-17-2009 10:55 AM In reply to
    hmm.. don't know..
    Tried 2 cables so far:
    8 pins - nothing works
    5 pins (aux cable) - makes light go green on MCL 2P when TV turned on, but gives no sound..
    What kind of powerlink cable should I buy?
  • 10-18-2009 1:14 PM In reply to
    • kallasr
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Had the same problem (MCL 2P would not turn on). This cable solved my problem.
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 10-18-2009 2:30 PM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Gordon38:
    If I'm not mistaken you can choose to go for speaker 1,2,3 which means you can choose which sourse of speakers you want to listen to.
    I alreade have one MX4002 my self but only use a pair of passive on to listen to.
    I doubt if I would be using an MCL2P on it. From my point of view it just doesn't make any sence.
    Best regards
    Spiros
  • 10-19-2009 6:07 AM In reply to
    • kallasr
    • Posts 1,077
    If have a set of beovox 3000 connected to my mx4000 (testing this setup) - no sound from the tv, just the speakers.
    No mcl2p needed...
    Ralf
  • 10-19-2009 6:42 AM In reply to
    kallasr:
    How did you manage that...? From what I know looking at the schematics (and in practice with my MX6000), there are no switches or switching between the external and internal speakers. They are connected directly in parallel. A headphone plugged in would mute them both, though.
    Do your internal speakers work at all if you unplug the 3000's?
    -mika
  • 10-19-2009 7:06 AM In reply to
    • kallasr
    • Posts 1,077
    I will test tonight.
    Ralf
  • 10-19-2009 12:06 PM In reply to
    Picked up a PowerLink Mk2 cable from Beostore today.. no success Sad
    Powers up nice (green light turns on) but no sound.. How can I tell if the line output is damaged/not working? is there a circuit somewhere?
  • 10-19-2009 2:17 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    are you silver or gold member? if so there is a circuit diagram in the manuals / service area that you can download ie on the mainsite product section
    t
  • 10-25-2009 4:35 AM In reply to
    • kallasr
    • Posts 1,077
    tournedos:
    kallasr:
    I was wrong, sound from the center (TV) as well. This changes only with Powerlink in use (now I upgraded to Beolab 4500). Getting closer to the final setup...BC 9300, BL4500, Beovision MX4000...just waiting for a long Aux Cable from Steve.
    Ralf
