1st March February 2012
Latest post 10-25-2009 4:35 AM by kallasr. 13 replies.
10-16-2009 3:15 PM
Gordon38
- Joined on 01-22-2009
- Denmark
- Posts 21
MX-4002 and passive speaker via MCL 2P
Just bought an old MCL 2P to be used with MX-4002 in my garage.. MCL 2P connected to MX-4002 via powerlink.. Turned on PL-socket in menu.. but no sound
MCL 2P has a red light - will this change to another color when in use? Could it be my cable? only connected 1 cable to socket 1 (think it is a standard power link cable from my BL 4000)
Any ideas what could be wrong?
Thanks..
AdiS
- Joined on 07-24-2007
- Posts 196
Re: MX-4002 and passive speaker via MCL 2P
Hello Gordon,
you don´t need the MCL 2P - the MX 4002 - as well as the MX 4000 - has two speaker sockets for passive speakers on the backside! So you can directly connect your passive speakers!
regards, Adrian
stotty1111
- Joined on 12-16-2007
- UK / France - Nth Worcestershire/Finistere
- Posts 924
try switching tv off then on - the 2p light should change to green and the speakers boot up!
good luck
tony
I always try to operate using/following the KISS principle -- Keep it simple stupid!
Gordon38
- Denmark
- Posts 21
Speakers directly connected to MX-4002 works fine, but I would like to turn off the tv speaker..
Tried to turn on/off several times :-(
Any ideas on the cabeling? I can'y connect a powerlink cable wrong?? can I?
AdiS
- Posts 196
is it a full wired powerlink-cable?
Gordon38
- Denmark
- Posts 21
hmm.. don't know..
Tried 2 cables so far:
8 pins - nothing works
5 pins (aux cable) - makes light go green on MCL 2P when TV turned on, but gives no sound..
What kind of powerlink cable should I buy?
kallasr
- Joined on 04-19-2007
- Willich, NRW, Germany
- Posts 1,077
Had the same problem (MCL 2P would not turn on). This cable solved my problem.
Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
Spiros
- Joined on 09-03-2007
- Thessaloniki GREECE
- Posts 1,088
Gordon38:
If I'm not mistaken you can choose to go for speaker 1,2,3 which means you can choose which sourse of speakers you want to listen to.
I alreade have one MX4002 my self but only use a pair of passive on to listen to.
I doubt if I would be using an MCL2P on it. From my point of view it just doesn't make any sence.
kallasr
- Posts 1,077
If have a set of beovox 3000 connected to my mx4000 (testing this setup) - no sound from the tv, just the speakers.
No mcl2p needed...
Ralf
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
kallasr:
How did you manage that...? From what I know looking at the schematics (and in practice with my MX6000), there are no switches or switching between the external and internal speakers. They are connected directly in parallel. A headphone plugged in would mute them both, though.
Do your internal speakers work at all if you unplug the 3000's?
kallasr
- Posts 1,077
I will test tonight.
Ralf
Gordon38
- Denmark
- Posts 21
Picked up a PowerLink Mk2 cable from Beostore today.. no success
Powers up nice (green light turns on) but no sound.. How can I tell if the line output is damaged/not working? is there a circuit somewhere?
stotty1111
- Posts 924
are you silver or gold member? if so there is a circuit diagram in the manuals / service area that you can download ie on the mainsite product section
t
kallasr
- Posts 1,077
tournedos:
kallasr:
I was wrong, sound from the center (TV) as well. This changes only with Powerlink in use (now I upgraded to Beolab 4500). Getting closer to the final setup...BC 9300, BL4500, Beovision MX4000...just waiting for a long Aux Cable from Steve.
Ralf
Page 1 of 1 (14 items)
