1st March February 2012
Latest post 12-27-2009 3:22 PM by beolion. 32 replies.
10-15-2009 9:05 AM
martin01
- Joined on 04-17-2007
- Sweden
- Posts 207
New Software released for BV7-40 Mark III/IV and BS3
I talked to my dealer today. New software 7.02 is released for BV7-40 mark III/IV and BS3. It replaces the "old" 6.11.
It would be interesting to know what changes is done with the new software.
Regards
Beolab 5 with sw 3.0, BV7-55 3D without Bluray(MK II), Beolab 7-4, Beolab 4000 MKII, Beolab 3500, Beovox CX100, Beosound 9000 mkIII, Cabinett 2054, Beo4 MKII, Oppo BDP-93 Blurayplayer (B&O-version)
Tillquist
- Joined on 05-26-2007
- Denmark
- Posts 211
Re: New Software released for BV7-40 Mark III/IV and BS3
Have can I chek the sotfware version in my BV 7-40 mk.III ?
My Bang & Olufsen....
- BeoCenter 2 DAB/DVD mk.II
- BeoVision 7-40 DVD mk.III
- BeoLab Penta mk.III
- BeoLab 4000 icepower
- BeoLab 4000
- BeoLab 3500
- Beo 5
- Beo 4 mk.I & mk.III
- Beocom 6000
- A8 Earphones
Michael
- Joined on 05-23-2007
- Atlanta, USA
- Posts 318
It better be something special to earn a whole "7" in the title.
Quim43
- Joined on 11-15-2007
- Tarragona (Catalonia)
- Posts 1,030
koning:
Can you tell me what the other improvements are.
Sure
On-screen menus are changed (also black menus)
Sleep timer function.
You can add additional HDMI sources connecting an HDMI Expander to the HDMI B socket.
Speaker mode 1 can be selected as standard setup in Video mode even if front and rear speakers are in the setup.
If used with RS4 software or higher on DVB-HD, then MHEG is possible in UK.
Regards
moxxey
- Joined on 04-14-2007
- South West, UK
- Posts 2,360
Quim43:
But these were all present in the v6.xx sw update? My BV7-40 MKIV has these features and it has sw 6.03.
Quim43
- Posts 1,030
moxxey:
Quim43:
I was talking about new SW for the BV8-40, not for the 7-40
moxxey
- South West, UK
- Posts 2,360
Quim43:
Ah, I was just following the title of the thread - assumed you meant the new sw 7.x features for the BS3.
beolion
- Joined on 10-20-2009
- Posts 245
I was just told today, that an update to my BV7-40 MKIV will come in week 47, will fix many bugs, i.e. humming noise when watching BR or music from my BM5 (connected with s/pdif).
/Leo
There is something about B&O.....
Quim43
- Posts 1,030
New SW 7.05 (Build 551) valid for Beosystem 3 based TVs has been released today. It fixes this:
1. No menu, no overlay menu, no curtains (Build 548). 2. Menus and OSD disappeared (Build 548). 3. BeoSystem 3 freezes when receiving DTV+CINEMA_OFF from standby (Build 548). 4. TV does not go into standby, and standby diode is blinking (slow flash) (Build 548). 5. Intermittently the television switches off (Build 548). 6. ACM crashes when source is YPbPr in High-Definition (was solved in Build 533) (Build 548). 7. No volume bar after using EPG in DVB-HD (Build 548). 8. Panel info says 50 Hz and not 100 Hz (Build 548). 9. No link control of DTV source (STB), if main room television is in standby (was solved in Build 533). 10. Lip-sync on Blu-ray does not match. 11. Timer on DTV-RADIO. Turn on to last shown TV (DTV) channel when link TV is connected. 12. Non B&O screen: Screen switches on when switching off from audio mode. 13. Not correct channel is showed when Play timer from another favourites list is programmed. 14. Difference in sound level between DVB picture and DVB Full-text. 15. Different issues with opening and closing curtains (half open-half closed). 16. Mixed sound from Radio and DVD in link room. 17. Stand does not always turn to stored positions.
Regards
mawheele
- Joined on 12-05-2007
- Posts 82
I hear 7.1.1 is now out. Does anyone have the fix list for this by any chance? My TV is coming back from an upgrade to Blu-Ray today which is all very exciting and will hopefully have been updated to the latest rev. Outstanding service from the guys in Reading as ever - they loaned me a 7-40 replacement whilst mine went away and couldn't have been more helpful.
Anyone else done the Blu-Ray upgrade yet. How was your experience?
Mark.
Quim43
- Posts 1,030
mawheele:
Mark.
0.7.1.1 is the lastest version of the Service Tool Mk2, but the lastest SW for the BV7-40 Mk3/Mk4 is the 7.05 (build 551). Maybe you have missunderstood it.
Regards
moxxey
- South West, UK
- Posts 2,360
mawheele:
These sw updates don't fix my major 'HDCP crashing issues' I've experienced since I bought the BV7-40 MKIV. It's a known problem, too. Glad to see they are giving it top priority
Peter2
- Joined on 05-01-2008
- Posts 51
moxxey:
mawheele:
Recently had my BS3/BV4 updated to 7.05, and the engineer suggested that the current thinking was that the HDCP crashing issues may be related to the new programme guide on Sky HD!
Certainly the timescale would seem to fit in with my recollection of when the intermittent crashing developed on my set up.
The television promptly crashed of course immediately after the update so I can confirm the current software fixes nothing on this issue; though fingers crossed as all fine this week!
P
moxxey
- South West, UK
- Posts 2,360
Peter2:
You could be right....as my crashing started around May, just when the new Sky HD guide was introduced!
But, why does it only affect the BV7 and not the BV8? Indeed, I can still carry on using the Sky box, with the BV8, once the BV7 has crashed!
My crashing is up-and-down. I can have two weeks with no crashing whatsoever, then suddenly it crashes - without warning - every 15 minutes, constantly, for a day or two. Then it doesn't do it for days again....! Argh :(
Peter2
- Posts 51
moxxey:
Peter2:
Yes, a couple of weeks without a hitch and then...a couple of crashes. But what is bizarre, and just has to be coincidence, is that it has always happened when I have been on Ch5 - mostly Flash Forward!
P
Peter2
- Posts 51
Crashed...Ch 5 Flash Forward (again)...spooky.
sja
- Posts 18
Hi Quim43.
Just been talking to my dealer about my beovision 8 40´.
And he dosn´t know anything about the new SW..:-(
were can i get it?
would like the upgrade.: black menu. And the opertunaty to swich to speakermode 1 :-)
Regards Shaun
Quim43
- Posts 1,030
sja:
Hi Quim43.
were can i get it?
Regards Shaun
Hi Shaun
Well, I think your dealer has to talk with his technicians. In our store, I do the updates for our customers. I think every store has to have someone to do it.
Regards
sja
- Posts 18
Thanks for your answer :-)
But am i right, that it is only the dvb hd modul, that you can update with a usb key?
And not the sw off the tv.?
Shaun.
Quim43
- Posts 1,030
sja:
Shaun.
You are right. With the USB Key you can only update the DVB-HD. You need a laptop and a special cable to update the TV.
sja
- Posts 18
Thanks a lot mate ;-)
ill contact my dealer tomorrow :-)
