Thanks for that, i will update the menu accordingly!
They are currently set to 'corner' as they are in the corners! i did try 'free' first but still experimenting
I take it, in a 5.1 surround set up that with the subwoofer turned off in the menu, that the signal for the bass is sent to the front speakers?
Thanks again
Ray
