Latest post 10-07-2009 11:11 AM by tournedos. 5 replies.
Page 1 of 1 (6 items)
  • 09-30-2009 3:54 PM
    Straightening warped records
    I have some records that are more or less warped. Tracking problems aside, now that I only have B&O turntables I can't really play them since all the decks seem to have very little clearance under the tone arm by design.
    I used to try and do something about warped records when I was a wee kid and being mostly successful as well, but can't really remember the details... I think I put them flat in a very mild oven (+50°C?), then let them cool down flattened by some weight. Does this sound plausible, or does anybody else have other methods for straightening records?
    -mika
  • 10-01-2009 12:45 AM In reply to
    • mediabobny
    • Top 200 Contributor
    • Joined on 04-19-2007
    • Greenwich Village, NYC
    • Posts 336
    Re: Straightening warped records
    Yes, tho heard you can go as high as 150F (65C?).  Keep it pressed till it cools.  Still hit or miss; depends upon the type of vinyl used.
  • 10-01-2009 8:02 AM In reply to
    Hi there! I've read somewhere you have to put the record in the oven, pressed between two clean glass plates. See http://www.associatedcontent.com/article/188522/how_to_fix_a_warped_record.html. Never tried it though ...
  • 10-01-2009 8:54 AM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Failing that Mika, turn the oven up a bit. Then they make great plant pot holders.
    Poor me, never win owt!
  • 10-07-2009 11:04 AM In reply to
    • 1203
    • Not Ranked
    • Joined on 04-27-2007
    • Posts 25
    I have tried a hair-dryer, sometimes with success sometimes dont. Is there really no way of adjusting the height of the tone-arm carriage on tangential B&O Beograms?
  • 10-07-2009 11:11 AM In reply to
    Well I guess most of them have a height adjustment - but then the pickup to record angle won't be correct anymore. I don't want my straight records to sound worse just so I can play an odd Rolling Stones compilation I've inherited Big Smile
    -mika
