Latest post 09-23-2009 10:40 AM by archie. 7 replies.
Page 1 of 1 (8 items)
  • 09-21-2009 8:26 PM
    • mediabobny
    • Top 200 Contributor
    • Joined on 04-19-2007
    • Greenwich Village, NYC
    • Posts 336
    CD Lens Cleaners
    On page 4 of the Beosound 1 User Manual, under Maintenance they state: "We do not recommend using special cleaning CD's in the Beosound 1".
    Anyone know why?  I've used them to great success in the past and am therefore curious.
  • 09-22-2009 7:01 AM In reply to
    • Kokomo
    • Top 100 Contributor
    • Joined on 08-21-2007
    • Spain
    • Posts 618
    Re: CD Lens Cleaners
    I think they are just covering themselves in case of claims under warranty. A lens cleaner usually involves a brush cleaning the lens, something which can go wrong with such a delicate mechanism as a laser lens. If they have advised against it, then if you decide to use one and it damages something they can turn around and say "we told you so"!
  • 09-22-2009 12:21 PM In reply to
    The brush cleaning  lens works very well.
    No problem at all.Smile
  • 09-23-2009 5:17 AM In reply to
    • Kokomo
    • Spain
    • Posts 618
    koning:
    Do you mean cleaning works well with all lens cleaning products on the market and with all CD mechanisms, or are you just summarising your own experiences?
    The two are very different.
  • 09-23-2009 5:51 AM In reply to
    It's my own experience.
    I own a beosound9000 and after brush cleaning everything works fine again.
    I've done that 3 years ago.Smile
  • 09-23-2009 6:01 AM In reply to
    • archie
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Paris
    • Posts 497
    I had a problem with my BS9000.
    i've changed the laser mechanism 1 years before.
    Sometimes when i put a cd it's pin very very fast in the wrong direction Confused
    may be to remove the dust from the lens with the wind ?
    I use a cd with brush and now all is OK.
    DU BEAU, DU BON, DU BO.
  • 09-23-2009 8:33 AM In reply to
    Hi Archie,
    My BS9000 has same problem as you had, just to reconfirm what you said, after you use the CD lens cleaner(with brush), it never happen again ?!?!  I think I will try that.
    James
  • 09-23-2009 10:40 AM In reply to
    • archie
    • Paris
    • Posts 497
    Yes, now all is ok, but the laser was not very old.
