Puncher:
Why not WMP versions later than 10? My WMP 11 claims to do the following rips -
Because, if I remember correctly, WMP 11 has limited functionality compared to 10, is a S*d to edit and I also think no longer retains Advanced Tag Editing which makes adding decent album art resolutions a snip.
I'm also sure there are thousands of apps that can do this better than WMP but I have a life and WMP just seems to do what I need.
However, speaking of life, if you want to waste a good deal of it, I strongly suggest you use Beoplayer to rip all your CD's. It takes an eon just to rip a single CD and another to edit it should you wish.
10%
