Latest post 09-16-2009 7:13 AM by Stephan. 1 replies.
Page 1 of 1 (2 items)
  • 09-16-2009 5:12 AM
    Mac mini no sound on BV5
    So have finally got my new mac mini properly connected (image wise) to my BV5, needed a VGA to Video adaptor full of electronics instead of a simple one.
    I can't get any sound from the TV, I have the mini connected to the BV5 optical digital cable -> converter -> digital coaxial cable and into the second connector behind the TV, in the first one I have my DVD player connected and it works great.
    Is it that I have the mini's digital output wrong in some way? Or should I just give up, and connect it via RCA cables? The first option is the preferred one of-course.
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 09-16-2009 7:13 AM In reply to
    Re: Mac mini no sound on BV5
    Had the same issue a month ago with my BV7-40.
    The digital to coax adapter sould work and deliver full 5.1 but you have to care that:
    - You have the latest TV firmware installed (gives some extra features as well)
    - Don't choose "PC" as a source (this worked for me), take DVD2 instead
    - Choose digital output in "Sound" and "DVD Player" settings on your Mini
    Hope that helps.
    rgds
    Stephan
