ideally looking for a complete working system . I have just aquired a mint MMC1 and feel it needs something better than my BC7700 to put it through its paces. I do have a Beomaster 8000 which works but can be a bit dodgy after a few hours use ( overheating?) . will pay decent prices for good condition..
thanks in advance
Justin
You might want to change the title of your post, the Beolab 8000 is an active speaker, I think you mean Beomaster!
Simon
Hi Simon , not according to Tims Jarmans "bible" on B&O - beocentral.
But thanks for the advice .
Quite right! The Beolab 8000 system is the correct description. I actually have the full system including MS150s and it is well work seeking out.
I bow to your superior knowledge!
Good luck!
It took me three-ish years to find mine, and then I had to get the individual bits and have them repaired in Hampshire and Denmark!
I'm very envious !! it must be a real pleasure to have the full system. I was fine with my beocenter 7700 untill i was shown( and heard) the full
8000 system in all its glory. Now, of course, I completely hooked!!
Hi - I have a master and 8002, and also a fully working Beocord 8000. (all rosewood)
If you are interested, please check the for sale section!
