Latest post 09-25-2009 12:11 PM by ........... 7 replies.
Page 1 of 1 (8 items)
  • 09-14-2009 9:37 PM
    beolab 8000 system wanted with remote in rosewood
    ideally looking for a complete working system . I have just aquired a mint MMC1 and feel it needs something better than my BC7700 to put it through its paces. I do have a Beomaster 8000 which works but can be a bit dodgy after a few hours use ( overheating?) . will pay decent prices for good condition..
    thanks in advance
    Justin
  • 09-15-2009 3:56 AM In reply to
    Re: beolab 8000 system wanted with remote in rosewood
    You might want to change the title of your post, the Beolab 8000 is an active speaker, I think you mean Beomaster!
    Simon
  • 09-15-2009 1:28 PM In reply to
    Hi Simon , not according to Tims Jarmans  "bible" on B&O - beocentral.
    But thanks for the advice .
    Justin
  • 09-15-2009 4:34 PM In reply to
    Quite right! The Beolab 8000 system is the correct description. I actually have the full system including MS150s and it is well work seeking out.
  • 09-15-2009 4:38 PM In reply to
    I bow to your superior knowledge!
    Simon
  • 09-15-2009 5:28 PM In reply to
    Good luck!
    It took me three-ish years to find mine, and then I had to get the individual bits and have them repaired in Hampshire and Denmark!
  • 09-17-2009 11:56 AM In reply to
    I'm very envious !! it must be a real pleasure to have the full system.  I was fine with my beocenter 7700 untill i was shown( and heard) the full
    8000 system in all its glory. Now, of course, I completely hooked!!
  • 09-25-2009 12:11 PM In reply to
    Hi - I have a master and 8002, and also a fully working Beocord 8000. (all rosewood)
    If you are interested, please check the for sale section!
