Latest post 09-14-2009 3:43 AM by timhanna. 5 replies.
Page 1 of 1 (6 items)
  • 09-13-2009 7:05 AM
    • CraigB
    • Not Ranked
    • Joined on 05-19-2007
    • Cannock, W. Mids
    • Posts 76
    BeoVision 7-40 volume
    Is there a way of limiting the volume at all?
    I would like to limit the volume so that it cannot be used above a set level, would this be possible?
    BV7-40 (early model)
    BeoLab 8000 fronts
    Beolab 6000 rears
    TIA
  • 09-13-2009 7:26 AM In reply to
    Re: BeoVision 7-40 volume
    i remember seeing it somewhere on the service (MENU + 0 +0 +GO) menu. check all the options...
    look for: Maximum volume 90
  • 09-13-2009 7:41 AM In reply to
    • CraigB
    • Not Ranked
    • Cannock, W. Mids
    • Posts 76
    Thank you very much, I will try it and report back Smile
    Do I hold the Menu button then press 0,0,Go?
  • 09-13-2009 8:04 AM In reply to
    No
  • 09-13-2009 1:05 PM In reply to
    • CraigB
    • Not Ranked
    • Cannock, W. Mids
    • Posts 76
    Worked like a charm, Thank you timhanna, I've reduced the Max volume to 50 and it's more than enough Smile
  • 09-14-2009 3:43 AM In reply to
    No worries at all, enjoy :)
