Is there a way of limiting the volume at all?
I would like to limit the volume so that it cannot be used above a set level, would this be possible?
BV7-40 (early model)
BeoLab 8000 fronts
Beolab 6000 rears
TIA
i remember seeing it somewhere on the service (MENU + 0 +0 +GO) menu. check all the options...
look for: Maximum volume 90
Thank you very much, I will try it and report back
Do I hold the Menu button then press 0,0,Go?
No
Worked like a charm, Thank you timhanna, I've reduced the Max volume to 50 and it's more than enough
No worries at all, enjoy :)
