Latest post 09-25-2009 3:21 AM by BegBeo. 5 replies.
Page 1 of 1 (6 items)
  • 09-04-2009 12:42 PM
    • Mohawk
    • Top 500 Contributor
    • Joined on 01-30-2008
    • Sweden
    • Posts 103
    • Gold Member
    Transformer beolink 7000
    Im looking for a mains power transformer 220/240v for beolink 7000 table charger, anyone?
    /Fredrik
  • 09-08-2009 4:00 PM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Re: Transformer beolink 7000
    Try Conrad.fr  they have a whole range of transformers - someone might know the output voltage / amperage so comparing size with dims of a new unit would probably come up with somthing!
    t
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 09-10-2009 5:18 AM In reply to
    Hi Fredrik,
    I don't have a spare transformer, but I can measure mine if that helps?
    -mika
  • 09-17-2009 4:09 PM In reply to
    • AT
    • Joined on 04-16-2007
    • Posts 187
    I have a table charger - but I'am wondering Your question, because the transformer is built in it, it's not separated.
    Anyway if it helps - the floor stand's separate transformer operates at 9V.
  • 09-18-2009 11:47 AM In reply to
    • Mohawk
    • Sweden
    • Posts 103
    • Gold Member
    Thanks for all answers.
    I need to replace the transformer inside the charger from 120v to 230v in the table charger or get a complete european tablecharger instead. I dont like to use an external stepdown 230/120v transformer as I do at the moment.
    /Fredrik
  • 09-25-2009 3:21 AM In reply to
    • BegBeo
    • Not Ranked
    • Joined on 04-23-2008
    • Stockholm - Sweden
    • Posts 60
    • Gold Member
    I have such a charger - Desktop Charger
    regards
    Jan
