Im looking for a mains power transformer 220/240v for beolink 7000 table charger, anyone?
/Fredrik
Try Conrad.fr they have a whole range of transformers - someone might know the output voltage / amperage so comparing size with dims of a new unit would probably come up with somthing!
t
I always try to operate using/following the KISS principle -- Keep it simple stupid!
Hi Fredrik,
I don't have a spare transformer, but I can measure mine if that helps?
-mika
I have a table charger - but I'am wondering Your question, because the transformer is built in it, it's not separated.
Anyway if it helps - the floor stand's separate transformer operates at 9V.
Thanks for all answers.
I need to replace the transformer inside the charger from 120v to 230v in the table charger or get a complete european tablecharger instead. I dont like to use an external stepdown 230/120v transformer as I do at the moment.
