Latest post 06-09-2007 4:30 AM by Beo. 13 replies.
Page 1 of 1 (14 items)
  • 06-07-2007 1:07 PM
    • Beo
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Posts 108
    is it a problem for beocom 4?
    When using beocom 4, I find that when I speak with normal loudness, I can hear my voice from the speaker at the same time, but the feeling is ... the sound seems not come from the speaker , and sometimes I feel this sound is a little bit cracking. I wonder if you have experienced this before or not. Is it normal for beocom 4?
    Filed under:
  • 06-07-2007 1:16 PM In reply to
    Re: is it a problem for beocom 4?
    How old is your Beocom 4 ?
    Have you always had this problem or has it just occurred ?
    Regards Keith....
  • 06-07-2007 1:39 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    No problem like that on my Beocom 4.
    CraigBig Smile
  • 06-07-2007 2:09 PM In reply to
    • Christian
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Copenhagen, Denmark
    • Posts 626
    Maybe the ecco is generated in the reciever's phones. You can check this by having the guy you speak with muting the microphone. If this helps then you don't have a problem, if not you could have a faulty phone.
    Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
    Addicted? Oh no.... ;)
  • 06-07-2007 10:57 PM In reply to
    • Beo
    • Posts 108
    well, it is not echo, echo comes a little bit later than my voice. But for this case, when i speak, it seems that I can hear my voice louder when the phone is stick to my ear.
    It seems that the sound does not come from the speaker.
  • 06-08-2007 2:47 AM In reply to
    Beo,
    I understand the symptom you have described, but the reason I asked the two questions before is that there was a software change that effected sound reproduction, so
    Regards Keith....
  • 06-08-2007 4:42 AM In reply to
    • Beo
    • Posts 108
    I appreciate your help, thank you very much.
    well, it is a very new one, just a month old only. This happens since the first day I use it till now.
  • 06-08-2007 4:52 AM In reply to
    Beo:
    That certainly isn't right then. I only got a new BeoCom 4 recently and the sound reproduction has been excellent and with no such problem. Contact your dealer.
  • 06-08-2007 5:04 AM In reply to
    Beo:
    As Henry said it is not right, return it to your dealer and ask for a replacement.
  • 06-08-2007 12:23 PM In reply to
    I agree with others, you have a faulty BeoCom 4 which is under warranty, so you should get a replacement from your delaer.
    Regards Keith....
  • 06-08-2007 10:40 PM In reply to
    • Beo
    • Posts 108
    well, thank you all of you.
    I have contacted B&O repair service technician, his reply is that it is normal to listen our own voice from the speaker area. They even use this to judge if the phone is okay or not.
    I discover that the problem only happens if I speak loudly (compartively), since today when I speak gentlely, it is perfectly okay. But if I speak loudly, I can hear my voice, and sometimes a little bit "cracking" like noise sound.
    So what do you think?
    Also, please help me to do an experiment. Connect the line without pressing number, I guess you should hear a long "Do..." sound, then try to speak a little bit louder at this time, I can hear my voice loudest in this situation from the speaker.
  • 06-09-2007 2:53 AM In reply to
    Beo:
    Ask him to bring you another BeoCom4 and test it, if it is the same then fine, if not demand a replacement.
  • 06-09-2007 4:06 AM In reply to
    • Ryan
    • Not Ranked
    • Toronto
    • Posts 29
    Mine has an echo as well when I turn up the volume beyond 60%. But I guess I shouldn't expect much for only nine times the price of a normal cordless phone.
  • 06-09-2007 4:30 AM In reply to
    • Beo
    • Posts 108
    i always keep it in the 3 loudest volume level. Will this affect much?
