Latest post 08-18-2009 4:06 PM by Xseries. 2 replies.
Page 1 of 1 (3 items)
  • 08-18-2009 2:15 PM
    Beosystem 6500 "No Contact"
    Hi, my Beosystem 6500 displays "no contact" on the master control panel when ever I use the remote control, I have replaced the batteries in the remote but cannot get the remote to work. all items on the system work if operated manually, is there a reset or setup configuration needed as I cannot find anything in the manual about this message.
    Any information would be greatfully received.
    Dipstikk
  • 08-18-2009 3:25 PM In reply to
    • YannChris
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Larmor-Plage, France
    • Posts 276
    Re: Beosystem 6500 "No Contact"
    Hello,
    This happens sometimes with Beolink 5000 when it is set as a one-way remote.
    Maybe you have the same option on the MCP.
    Yann.
    Ne pas s'en faire et boire frais!
    Mon install en images: cliquez sur mon profil, au dessus de mon avatar - Puis "My files" tout en bas.
    Pictures of my setup: click on my nickname, above my avatar. Then "my files" at the bottom of the page.
  • 08-18-2009 4:06 PM In reply to
    • Xseries
    • Top 150 Contributor
    • Hampshire
    • Posts 433
    There is no option on the MCP for 1 way remote.  Try switching the unit off at the mains  - wait a couple of minutes and reconnect.
    Have you any other equipment (eg TVs etc) that you might have programmed by accident that may have caused the option numbers to change?
