We recently purchased an Apple Macbook Pro and were very impressed. We began thinking of replacing our PC desktop with an iMac. Before doing so I disconnected our Beoport from the PC and connected it to the Macbook as well as installing the appropriate software. Everything worked fine.
Tonight we purchased a 24 inch iMac and after spending two hours transferring files from the old PC it came time to connect Beoport. Here the problem occurs. When I went to plug the cable into the iMac headphone jack it pops out, almost as if a spring is forcing it out. I checked the cable by installing it into the audio in plug, it fit perfectly, and it again fit perfectly in the Macbook Pro.
Am I doing something wrong in connecting the cable to the headphone out? Or did we get a defective iMac as the headphone out will not accept a cable?
Thanks!
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
