Just got my Beo5 remote shipped from the dealer. My first concern about the remote is the volume wheel. It doesn't seem to turn freely, i.e. it jams (slightly) when turned. Since the surface of the wheel is slippery it is somewhat awkward to adjust the volume.
Has anyone had the same "problem" after receiving their Beo5? Is this normal since the remote (aught to be) is brand new and should I just use it for a while to break it in? If not, is there a solution to make the wheel turn smoother other than sending it back to the dealer?
Regards!
