Latest post 08-13-2009 10:52 AM by Large48. 7 replies.
Page 1 of 1 (8 items)
  • 08-06-2009 2:33 PM
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    shelf for mx7000? tv stand
    anyone out there got one? - hooked suspension type
    pm me if so
    tony s
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 08-07-2009 11:18 AM In reply to
    Re: shelf for mx7000? tv stand
    Hi I am based in Singapore. Are you looking for the motorised stand together with the DVD/Video shelf?
  • 08-07-2009 12:26 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    no just the shelf!
    t
  • 08-09-2009 12:56 PM In reply to
    Which version of the shelf are you looking for?
    The flat square one (V8000 type) or the 2 x long prong one (VX type)?
    Train Hard - Run Fast - Hit to Kill!!!
  • 08-10-2009 9:00 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Confused now and its only Monday! - the one i look for is like a ladder ie  2 bars coming forward with 2 bars across and the forward facing bars have a piece of channel iron welded on to hold it vertically the top of this piece has 2 spigots bent at 90* pointing forward these locate in 2 slots under the top plate and the vertical piece rests on the support tube to give the shelf a horizontal aspect - had one, gave it away about a month or so ago - now need one - sod's law rules!
    cheers
    t
  • 08-13-2009 3:48 AM In reply to
    That's the one for the VX video's.
  • 08-13-2009 6:59 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    ok my error - you got one ?
    now back in uk next time you're in midlands you want to view the bc 4000?
    t
  • 08-13-2009 10:52 AM In reply to
    Hi T,
    Think I do have one, I'll dig it out to bring with me next time I'm up your neck of the woods.
    Hopefully some time in the next two weeks.
    I'll PM you when ~I know a bit more.
    Cheers
