anyone out there got one? - hooked suspension type
pm me if so
tony s
I always try to operate using/following the KISS principle -- Keep it simple stupid!
Hi I am based in Singapore. Are you looking for the motorised stand together with the DVD/Video shelf?
no just the shelf!
t
Which version of the shelf are you looking for?
The flat square one (V8000 type) or the 2 x long prong one (VX type)?
Train Hard - Run Fast - Hit to Kill!!!
Confused now and its only Monday! - the one i look for is like a ladder ie 2 bars coming forward with 2 bars across and the forward facing bars have a piece of channel iron welded on to hold it vertically the top of this piece has 2 spigots bent at 90* pointing forward these locate in 2 slots under the top plate and the vertical piece rests on the support tube to give the shelf a horizontal aspect - had one, gave it away about a month or so ago - now need one - sod's law rules!
cheers
That's the one for the VX video's.
ok my error - you got one ?
now back in uk next time you're in midlands you want to view the bc 4000?
Hi T,
Think I do have one, I'll dig it out to bring with me next time I'm up your neck of the woods.
Hopefully some time in the next two weeks.
I'll PM you when ~I know a bit more.
Cheers
