Hi Everybody !
Before I start digging into my Ouverture, I`d like to ask if someone
in the community has encounter a similar problem.
The problem with my Ouverture is that is no longer willing to respond to commands. No response from the keypad , neither from the remote (I`m using a Beo4). The standby light stays on, the doors are working properly, the CD clamp is working. The problem occured after about 30 days the unit was not in use , nor plugged into mains , due to some home redecoration work. The unit is set to Option 1, as I`m using it as standalone item (with a pair of BeoLab 2500). The standby led blinks once when a button is depressed either on the keypad or on the remote. I mean when some buttons are depressed. Like CD, Radio, ATape, Program, Setup. Also the Ouverture won`t enter into service mode. It does not respond to any of the codes in the service manual. Seems not quite willing to cooperate, is she ?
Any help would be greatly appreciated.
Thanks!
