Latest post 08-08-2009 4:29 PM by Jan. 9 replies.
Page 1 of 1 (10 items)
  • 08-04-2009 10:10 AM
    Help me to configure
    I have Beo Center 2 and Beolab 8000 to configure to Belo 5.  However I am not able to make the DVD function works in Beo 5.  Any kind soul can help?
  • 08-04-2009 2:24 PM In reply to
    Re: Help me to configure
    What TV are you using? What happens when you press DVD on the remote? I have a BC2 and Beo5 and mine works with no problem using the standard DVD button. Do you have the software?
  • 08-04-2009 2:42 PM In reply to
    I'm using old Phillip LCD TV...
    Beo5 will display the DVD buttons but all of them are not working...
    From the software, I add "Beocenter 2" in "Choose Product" follow by Beolab 8000... then I want to add in "beocenter 2 DVD" under Video - Video Source - DVD, but not successfull.
    How did you managed to configured it?
  • 08-04-2009 5:37 PM In reply to
    To be fair, I can't remember, but I have a B&O set and the DVD appeared automatically. Have you thought about getting Keith to program your Beo5 - he can probably get it to work the Philips set as well.
  • 08-05-2009 1:19 AM In reply to
    I don't think Keith can physically do the work for me as I am in the Fast East.
  • 08-05-2009 1:47 AM In reply to
    He might be able to send you a completed XML file - worth asking.
  • 08-07-2009 5:51 AM In reply to
    I am sure I can assist you if required, no matter where you are in the world, as I have assisted members located in both the US and Australia without problems.
    If you have the Beo5 Configuration Tool and require a 3rd party XML file for a particular product, then please send me an e-mail stating what you wish to do.
    Regards Keith....
  • 08-07-2009 7:03 AM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    jasonkjyap:
    Is that implying we are slow in the West?
    Laughing
  • 08-08-2009 2:39 PM In reply to
    Keith,
    Thank you so much, but I have more things to add in to my system... it would be double job to set the configuration now...
  • 08-08-2009 4:29 PM In reply to
    • Jan
    • Not Ranked
    • Joined on 07-15-2007
    • Netherlands,Flevoland
    • Posts 27
    Last week Keith did help me,and he did a very good job.
