If your 4500 is two way, look for a Beolink 7000 - far, far better.
Make absolutely sure that your BM4500 is 2 way as there is no practical means of adding it afterwards.
Or......
Dont bother with 2 way and use a BL1000. Much the more sensible option!!!!! IMHO
Regards Graham
Have to agree with you Graham. Although I would prefer a Beo4 otherwise, but not having a direct PHONO button (or SHIFT for A.Tape2) is a nuisance.
-mika
The Beo 4 is what I use, but I can live with the inconvenience of the phono keystrokes as I don't have a phonograph
Evan
